Function Generator Control
I need to use LabVIEW to control a Tektronix AFG310 function generator.  I have the drivers for it which I've attached and the Example 1 VI is along the lines of what I think I need.  All I need is to set the function as: sine (inputs of amplitude and frequency), square (amplitude, frequency), a pulse train (amplitude, pulse time, interval), ramp (start/end voltage), and dc.  Could anyone give me any insight into what I need to add to the example vi to accomplish this?  Thanks
(3,512 Views)
Hi zuegz:
I'm not exactly sure what we need from this.  Without having access to this instrument, the LabVIEW code looks fine.  You should be able to select the type of waveform you want and then specify the frequency and the amplitude.
Where did you get these drivers from?
Emilie S.
(3,487 Views)
