Function 'Copy data' in the context menu of graphic objects do not work correctly
in the newest LabView 2011 version the function 'Copy data' in the context menu of graphic objects do not work correctly. In older Versions the cursor positions was copied correctly in the clipboard. In the new version it fails. See attached pictures. The graphic "B-Bild" in the application.jpg was copied to the clipboard.jpg. It seems that the offset and scaling values will not be considered. How can I use the 'Copy data' function in the new version correctly?
Best regards
uvo
(2,466 Views)
i try out your Problem, but with LabVIEW 11.0.0 it works fine.
Which Version of LabVIEW 2011 are you use?
Can you post your VI, too?
King regards,
Lorenz Casper
(2,438 Views)
thank you for your replay. Please find attached a sample VI with the same problem and the version info.
Best regards
uvo
(2,428 Views)
i talked to our specialists and they told my that this is a known issue.
Our Developers are working on it, but I can't tell you when this Problem will be solved.
Best regards
Lorenz Casper
(2,399 Views)
