Fuel Consumption
Please help for my question.I am trying to do fuel consumption . But I'm stucked
Fuel consumption of an engine will be calculated in lt / min and will be shown on the screen with two gauge type and numerical indicators. When the engine is running, the logic 1 is an electronic device that outputs and is connected to the digital input of the DAQ card. When the engine is running, “overload” warning will be active on the screen when the average value is 2 lt / min.
Requirements:
-NI USB 6003 data acquisition card will be used (to be added from MAX as simulated)
- Differantial analog fuel data will be read from AI0.
It is aimed to reduce the possible noise by finding the average of the 1 second series that is read with the sampling rate of -1kHz.
-Debi data is set to output 0-10 volts analog linear voltage for 0-0.1 lt / second.
- Digital I / O pin P1.0 will be used.
(Pay attention to lt / sec and lt / min conversions. Suitable flow conversion formula is required for 0-10 volt ADC data)
(3,249 Views)
Do you have a question or are you asking someone to write code for you? I did not see a question just a description of what you would like to accomplish.
Tim
GHSP
(3,225 Views)
Please try doing your homework yourself. If you get to some point where you have a specific question then come here and ask.
(3,222 Views)
ı sent homework because ı don't know where to start, and the logic I did not understand
(3,201 Views)
I dont want someone do my homework
(3,199 Views)
If you don't know where to start or understand the logic then perhaps you should be talking to your teacher. Have you read the course material? Have you attended the lectures?
(3,197 Views)
