Front panel resolutions: Application vs. VI mode...
This is probably a silly question but it caught me by surprise as I don't recall seeing this in any of the old versions of LabVIEW. When I run a LabVIEW program in the normal (VI/debug) mode the front panel resolution is very high and the fonts are smooth as if they are post script/vector graphics. But as soon as I compile the code to an application in the application builder the front panel/fonts become pixelated... as if it was a lower resolution bitmap. Below are two images, one from a normal VI (left) and the other (right) after it has been built into an application. What setting do I need to set to have the built/compiled application retain the same resolution as it has during normal (VI) mode? I am using LabVIEW 2021. Thanks! (If both images don't show it might be due to a temporary server problem. Not sure but the question should be clear even without the images)
(1,214 Views)
LabVIEW doesn't always play nice with Windows resolution scaling. Is your monitor scaling set to 100%?
(1,181 Views)
For this project I am using a Mac (mini) actually and the display setting in MacOS is set to the default of the display. Perhaps this issue is a Mac only issue? It is just strange that things changes just because I compile the code. I would expect that What-You-See-Is-What-You-Get... before/after compilation. Not a big deal but if there is a simple solution/setting I am all ears. Thanks!!
(1,162 Views)
Your computer likely sees the LabVIEW dev environment as a different application entirely from your created executable (which it is). It may apply different scaling settings to them, or even render one with a different graphics card than another. Unfortunately I'm a Windows guy, but I suspect this has to do with your computer, not your LabVIEW code. Hopefully someone with some Mac experience can help.
(1,158 Views)
Thanks. That makes sense. Seems like a LabVIEW bug on MacOS if there is no way around it with a setting. For comparisons I just tried LabVIEW 15 on Windows 10 and it does not have this problem with compiled applications and I also never recall ever having this problem in the past with LabVIEW on Windows. I have not used LabVIEW on Mac's since the mid 90s so I can't say if this is a new issue or not. Anyway, if any Mac users are on here and know how to fix this, please let us know. Thanks!
(1,124 Views)
