Front panel remains after terminating lavbiew application
I have created an application from a LabView VI.  I'm launching the application from LabWindows.  I'm monitoring for the application to terminate.  However, when I terminate the LabVeiw application, the LabView front panel is displayed and the LabWindows application terminated function doesn't see it as terminated until I close the front panel.  Why is the VI front panel being displayed when the application is terminated.  I have the program to run in dialog center screen.  Once the application terminates, the dialog disappears and the LV front panel appears.
(2,406 Views)
Modify your LabVIEW code, based on suggestions given here in this post:
http://digital.ni.com/public.nsf/allkb/4BE0544020D101AA8625687400638594
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,391 Views)
I like to put the Close invoke node inside of a Conditional Disable Structure.  This way the front panel only closes when you are running an EXE and not when you are playing with the code.
(2,365 Views)
