Front panel connections to connect to DataSocket Server
Why does its takes 2 to 10 mins for the front panel connections to connect to the DataSocket Server. Window Fire Wall is turn off.
(2,786 Views)
Hi g-c,
Please provide more information on what you're doing and how you have your software set up. What are you communicating between  and what software versions are you using?
Misha
(2,762 Views)
Misha
Labview Pro Ver 8.5.1,DataSocket Server Ver 4.5, Running on 3 computer ( controling  FP module), internal network with no DNS server, window firewall turn off.
We are updating  the system to turn-on/off and montior different equipment for testing. The DataSocket is use to pass status/setting of the different test equipment to the user. In the old version of the our software Datasocket wasn't a problem (writen in Labview 5.1 update to labview 7.1)
I have check under DataSocket Diagnostic and the datasocket are being show with the right read/write subscriptions, but sometime the datasocket don't appear to be updating.
Hope this help.
G-C
(2,741 Views)
g-c,
We have a knowledgebase  describing some possible causes and solutions for your datasocket delay problems. Please check if these steps solve your problem.
Misha
(2,720 Views)
