Front panel centered
How do you center a front panel display in LV7.1 ? ( ie the operator Interface) It is sometimes off centered and larger than the display. Can I use a property node ? Which one ? Tried "vi properties>auto center" they don't work
(3,698 Views)
Hi ,
The VI properties ,Window display ,Auto Center will make the front panel centered,you can also make use of the Property node property for front panel to make it autocentered.
If you yet have a problem why dont you attach the vi along so that we can have a look at it.
vicky
(3,698 Views)
Vicky,
Have a look at this.
(3,698 Views)
It appears that you're attempting to modify the full TestStand operator interface. One of the things that you've done is modify the window size property to be width and height of the entire screen. I'm not sure what other modifications you've made. I do know that the OI as shipped will center itself so if you could explain the other modifications you've made and the purpose of them, maybe someone could help a little more.
(3,698 Views)
Dennis,
If I changed things in the OI I didn't intent to. I'll just try and go back to the original OI shipped with TS.
Thanks for the help.
(3,698 Views)
sorry i cannot load the front panel in my PC.
vicky
(3,698 Views)
