Front Panel in Low Detail - Why?
I don't understand why my Front Panel is in low detail when I began to work today. All front panels of several applications is in way. See attached image.
How to do fix it?
Leonardo de S. Cavadas
Maintenance Engineer and Inspection - Bureau Veritas do Brasil
Engineer Metallurgist with emphasis in Advanced Materials
Technologist in Computer Science
Message 1 of 11
(4,348 Views)
What likely happened is your colour display depth was changed to 256 colours, or another low option.
Go to your display properties and change it back to true colour or high colour, or 32-bit colour, depending on your video card.
Message 2 of 11
(4,344 Views)
Dear Will,
thx for clue, but my display color already is in 1152x864, 32 bits color, 75hz mode. My video card support this without problem. What can be, then?
Message 3 of 11
(4,329 Views)
I don't understand...my video resolution is High, true color.....all work right except Labview. Look for attached picture.
Thx for any idea.
Message 4 of 11
(4,281 Views)
Leonardo,
I have been having some front panel quality issues aswell.  I posted the details of my issue in a different thread: (http://forums.ni.com/ni/board/message?board.id=170&message.id=222012) and someone pointed out to me that you are having similar problem.  Have found a solution yet?
Message 5 of 11
(4,215 Views)
Kahless,
Is really strang, but my problem disapeared like appeared - mysteriously.
The NI enginneer tell me a solution - reinstall Labview, but time is money and I didn't make this.
Sorry, but I haven't solution for this.
Message 6 of 11
(4,139 Views)
We have computers that demonstrate similar problems...
http://forums.ni.com/ni/board/message?board.id=330&message.id=13193
What make and model of PC are you running out of interest?
Chris.
Message 7 of 11
(4,104 Views)
Chris,
I'm using a P4 1.8Ghz, 512 mb, WinXP Professional with SP2, Geforce4 Ti4200, Screen resolution 1154x864, Quality 32 bits.
I didn't nothing for solve problem....The problem disapeared mysteriously.
Message 8 of 11
(4,087 Views)
Ta for that Leo,
Just curious was it an OEM supplied computer (ie. HP or Dell or similar) or a in house built computer?
If it was from another supplier could you be so kind as to provide model info? (eg. Hewlett Packard d530)
Thanks again,
Chris.
Message 9 of 11
(4,085 Views)
Corporate Supplied - IBM - Personalized Model
Message 10 of 11
(4,068 Views)
