Front Panel Terminal 'Section Cluster Refnum in':Hidden front panel control has undefined type.
That's not very informative 😕
Anyway, please check this post: http://forums.ni.com/ni/board/message?board.id=170&message.id=224900&requireLogin=False. Is your issue the same? If so, you could try the workaround that one of the members has suggested.
Vaibhav.
(3,605 Views)
Thanks for the link!  There's no workaround there but at least the problem is clarified and documented.
And the fact that this defect has been around since (at least) Jan 2007 is documented there as well.
(3,424 Views)
