Front Panel Open
I have 2 buttons in my VI. So whenever I click first button another VI should open. And whenever I click second button, one more VI should open. The opened VI should get hidden.
How can i do this in labview.
Thanks in Advance
Regards
Soundarya
(3,776 Views)
Hi Soundarya,
you can use the VI-Server functions to open and close the vi's.
See the attached example. (All vi's are created in LabVIEW 8.5)
Mike
(3,770 Views)
ok mike beat me to it
Message Edited by muks on 07-09-2009 03:24 AM
(3,760 Views)
Or go to VI Properties>Window Appearance and select Dialog. Call the VI normally and the front window will show.
(3,734 Views)
Why...?! Smiley Indifferent
Then, what is the very purpose of opening it in the first place? Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
(3,725 Views)
It is meaningful if you say that, when you open your 2nd VI, your 1st VI should get hidden. Smiley Wink
I m not sure whaat you are trying to do...
Can you explain your architecture a bit more?
(3,722 Views)
 Parthabe, I Have done that for data verification and checking
(3,697 Views)
