Front Panel - How to make text object change when a condition is met?
I am designing a semi automated procedure for verifying PXI-4224 cards. What I would like to have is a front panel similiar to the FP png attached.
Question #1:
I know it would be a true/false condition, but what object do I use to have pre defined text determined by said condition?
Question #2:
I am quite certian there are better/ more efficient ways of accompling what I would like, but I am doing the best I can with what I know. With that being said, How would I impliment the DAQmx Reset, SelfTest, and SelfCal to accomplish in the attached routine? I just need them to be acomplished and then drive the conditional text change (from above) occur.
(3,318 Views)
You can change the text that is writtne the same way you do any LabVIEW programming.
To change the color of the text, you can use a property node for that indicator to set the text color.
(3,296 Views)
