Front Panel Hangs when Image is Requested From WebServer
Hi Marti,
I found out the problem.
I did use the monitor option but I set to refresh every 3 second of the image.
Somehow it is too fast for my PC to handle and cause the hang.
I changed it to refresh every 10 second. Now it works perfactly.
Thank you for your help.
Lux
Message 11 of 12
(565 Views)
Thanks for letting me know!  When you do have a solution on a Discussion Forum, go ahead and mark that post as a "solution" so others searching the forums can quickly find the answer.
Cheers!
Marti C
NI Medical
Message 12 of 12
(551 Views)
