Front Panel Display
I have a decent sized control sequence that utilizes many sub VIs. Some of the subVIs are used several times and the front panel from the subVIs are displaying information. The issue I am having is that because the subVI is called in multiple different places, I need to open each instance of the front panel to see the information. Is there a way that I can have only one front panel open that updates each time any of those subVIs are run?
(1,971 Views)
Make the subVI non-reentrant (which is the default).
Your questions is too vague in general. Can you describe the project in more detail?
(1,968 Views)
Here is a picture, hopefully is clarifies!
(1,946 Views)
Truncated code pictures never clarify much.
(1,930 Views)
@KeplerRidge wrote:
 utilizes many sub VIs ... the subVIs ... front panel [of] the subVIs are displaying information....
Sound like you need to put the sub-vi's into your top level vi as a sub-panel.
Currently using LabVIEW 2022
(1,876 Views)
