Frequency scaling down of the signal
Hi Navin,
where did you set those "3MHz clocks"? They are not visible in your images…
(Unfortunately I cannot examine your code in all details because of some missing hardware support.)
Message 11 of 17
(1,008 Views)
Hi GerdW,
i have set the clock1 frequency in FPGA base clock properties window and here i am attaching image for your reference. please check it.
Message 12 of 17
(1,004 Views)
Hi Navin,
as I don't have experience (and hardware drivers) for this special kind of hardware I'm out of suggestions!
With a cRIO FPGA I would create a derived clock from base clock - or use a simple Wait function inside a plain WHILE loop…
Message 13 of 17
(998 Views)
Hi Gerdw,
i have generated the derived clock with 3MHZ for FPGA, signal frequency is 320KHz, output frequency  is ok now but output signal on the CRO seems like stepped sine signal..
i keep increasing the #samples also still it couldn't be solved
how to smoothen the signal can anyone please suggest me
regards
navin
Message 14 of 17
(976 Views)
Hi Navin,
do you mind to provide the current state of the project?
Can you attach some images of the waveforms you are worried about?
Message 15 of 17
(972 Views)
Hi GerdW,
i am updating the state of the project here
Now my timed loop is running at frequency is 3MHz SCTL, signal frequency is 320KHz @fs =3MHz
now i am getting output frequency almost equal to input signal frequency, but wave form is not a smooth sine wave, itseems like stepped sine signal.
Here i am attaching the project file and images of the signal on CRO..
please have a look at it and help me out
Message 16 of 17
(970 Views)
Hi Navin,
At fs=3MHz and sine frequency of 320kHz you get just 9 samples per period: I would expect nothing else than a "stepped" output signal…
I don't know where you see something like a "stepped sine wave". All I see is a ramp (aka sawtooth) signal with just 3 or 4 samples per ramp…
Message 17 of 17
(965 Views)
