Frequency peak detection and save to .csv file
I would like that the VI opens the .wav files which recorded by me, make an FFT and find the 5 highest frequency peaks and their amplitudes from the frequency bulges. And finally save this 5x2 values into .csv file for each .wav into a new .csv. Just the significant frequency and its amp point in two columns in .csv.
I started this program in Labview 19 and also save it into Lv16. I attached  pictures, the semifinished VI and some wav files. Sorry for my english!
Can somebody help me?
(2,247 Views)
You were close to finding peaks, then need to sort, and keep the 5 largest.  There are more elegant ways to do this, but here's one that follows your start (which was close to working).
I've also included a VI to do an alternative peak detection, which you might use to suppress unwanted side peaks without resorting to smoothing you just need to decide a peak must be > delta_Y from surrounding pts.
I've tested some of your data and it definitely works, though the parameters required vary from dataset to dataset.
Sorry I worked on the 2016 version in LabVIEW 2019 but used sort 2D array before realizing its not backwards compatible and couldn't back save.
Craig
(2,200 Views)
