Frequency meter
Hello. I need help developing a frequency meter for an AM / FM transmitter / receiver on an ELVIS II + based on LabVIEW.
The problem is that on HighFrequencywith2 Counters the frequency is not measured.
(2,919 Views)
I have no idea of the hardware capability, but just make sure that the frequency you are trying to measure do not exceed the maximum frequency the system can measure.
Benoit
(2,896 Views)
Hello Larisa
I would reference you this Wireless Frequency meter  These are industrial Grade Wireless Frequency Meter with the frequency range of 2 Hz to 10k Hz. It has 2 Mile Range with On-Board Antenna and 256 Sensor Node can be connected per Network. Even as per your requirement, It uses LABView application to monitor your values.
ThankYou
(2,872 Views)
