06-17-2010 06:37 PM
i need meter the frquency by this method:
The frequency reading shall be obtained every 10 s.
The frequency output is the ratio of the number of integral cycles counted during the 10 s time clock interval, divided by the cumulative duration of the
integer cycles.
The measurement time intervals shall be non-overlapping. Individual cycles that overlap the 10 s time clock are discarded. Each 10 s interval shall begin on an absolute 10 s time clock.
I need do this on normal Labview and on cRIO FPGA.
Any idea?
Tnkx a lot...
06-22-2010
09:13 AM
- last edited on
02-04-2026
11:22 AM
by
Content Cleaner
Did you try to find something in the examples on developer zone?
If you are using a CompactRIo in FPGA mode, you should visit IPNet too.
here is an example of frequency measurement [link removed 2/4/26; example no longer available] found on IPNet.
Olivier L. | Certified LabVIEW Developer
