Frequency Measurement
I´m using a Laptop with a Daq Card AI-16XE-50 and LabVIEW 4.1 and NI-DAQ 6.5.1.
I have a lot of SCXI modules (1122, 1160, 1162, 1180) and their terminal blocks.
I still want to measure the frequency of the pulses I have from an indutive sensor of proximity. I tried using the counter (measure frequency). But I can´t put it to work and if I could, I couldn´t count more than 2 counters. I need more than 6. I tried using the digital port (the sensor outputs a digital sign) and I constructed a VI, using a loop and sequence, that´s working. But when I use others VIs using analogic channels at the same time, I realized that the digital VI have some delay.Now I want to know, again, how should I do to measure my frequency. Should I transfo
rm the digital VI that´s working to analogic? Should I use some VI to measure the frequency assuming that my digital sign is analogic? (I tried the threshold peak detector before).
(3,201 Views)
hi rgarcia,
Measuring frequency using the digital lines of the board will not be the accurate way of measureing frequency. But those digital lines read the pulses based on software timing. Counters are best for measureing frequency but since you have only two counters, you can measure frequency of two signals.
Now the best option would be to use the SCXI-1126 frequency module to measure 8 frequency signals (from 0 to 128KHz range). You will get accurate frequency information based on hardware timing.
One more workaround would be to acquire the time domain signal using analog channls off of DAQCard then using the software routines, you can extarct frequency spectrum information from it. The example of such technique is "Benchtop Spectrum Analyzer.vi" under signal proce
ssing in labview.
A Rafiq
http://www.ni.com/ask
(3,201 Views)
If you end up acquiring the digital signal with analog channels, insure that the time resolution of the sampling rate is adequate for your requirements. Counter Timer resolutions are much better than analog sampling. I would not suggest the benchtop spectrum analyzer to measure the frequency content of a digital (square wave) signal. You are really looking for leading edge to leading edge period and this is a threshold delta time type calculation.
Stu
(3,201 Views)
If you can use the digital port, you can probably use the counter. If you have access to the PFI lines of your DAQ board, you can multiplex these PFI lines to the gate of 1 counter, and though the readings would not be simultaneous, you could read the frequency of up to 10 digital signals with one counter.
Check out the item on the NI website:
http://zone.ni.com/devzone/devzoneweb.nsf/opendoc?openagent&4229043E5852EC998625683A000A5410&cat=33E541E2AEBC0B5986256786000FC83D
This should show you the VI to do this.
Mark
(3,201 Views)
