Framed Color box question
In the attached program,I want to be able to control the color of the intensity graph using a framed color box.
I am confused about what numeric representation to use etc.
I was wondering if someone might be able to finish off this part of my program for me?
Message 1 of 9
(589 Views)
Accepted by topic author LED47
The colors of an intensity graph are defined by a color ramp of 256 values (8 bits). The range of z values gets mapped into that range. You can define the marker colors using property nodes.
For a simple 10x10 color board, you could just use a 10x10 array of frameless colorboxes instead.
(On a side note: Why would you need 4 diagram constants with a "10" value if one would be sufficient? Your indicator belongs after the loops, no need to update the indicator 100x in a nanosecond. You'll never see intermediary results unless you place a wait. Why all that code if you want all elements to be the same?)
Message 2 of 9
(568 Views)
In my test example I am indicating measurement results with color as I sweep XY across a wafer.
 I chose a 10 by 10 iterations as an example that would be similar to my program
Message 3 of 9
(556 Views)
An intensity graph is not a picture. The value of the input array is translated to a color using the Color Map and Zscale Range or Marker Values properties.
See the documentation: https://www.ni.com/docs/en-US/bundle/labview/page/intensity-graphs-intensity-charts.html
It also links to an example: labview\examples\Controls and Indicators\Graphs and Charts\Intensity Graphs and Charts\Intensity Graphs and Charts.lvproj
Use high color and low color to indicate out of range values.
intensity graph colorintensity graph color
Message 4 of 9
(546 Views)
Well as always thank you very much.
I've adjusted my program to reflect the example you gave me and now it works just fine.
Message 5 of 9
(536 Views)
Yes thank you very much that information is very helpful to me
Message 6 of 9
(534 Views)
Why do you divide by 255 and then multiply the result by 255 in the top loop? Seems a bit Rube..
Message 7 of 9
(493 Views)
First I wanted to use less colors, realized that is not possible and then did not clean it up.
The color table is fixed to 256 colors. If you wire a smaller array for the color table, only the first elements in the color table are replaced.
Message 8 of 9
(454 Views)
Thank You!
Message 9 of 9
(432 Views)
