Frame delays in sequencing
Is it always the case that sequence structures actually respect
sequencing?
I have placed positioning using a slow XY stage in frame 0
and noticed that when the XY stage's propagation time
is long (>2s), due to large X and Y coordinates, frame 1
begins executing before the positioning in frame 0 completes.
Does sequencing operate under a timeout constraint per
frame?
Thanks in advance,
Andrew
(2,559 Views)
> frame?
What is probably going on is that the I/O calls are made, and they
complete. So as far as LV is concerned, the function calls in sequence
0 are finished and it is time to go to sequence 1.
Look for a way to determine when the stage movement is completed. At
that point, you can also probably use dataflow to sequence rather than
using an actual sequence structure -- if you would like.
Greg McKaskle
(2,559 Views)
