Fortran DLL in LabView
I use Labview and want to implement property
routines. They are written in Fortran. I can
build a DLL and run it in VisualBasic (works).
The same DLL called by Labview gives the error:
"Can't find secondary DLL".
When I create a very simple one-line-DLL (eg
input**2) it works. As soon as I change the DLL
code to "the power of a fractional number", the
above error occurs.
I run Labview on Windows95, and use the latest
version of Visual Fortran Compiler from
DIGITAL/Compaq. (Labview is installed on a
different computer as the compiler.)
Who has some ideas for this very specific, but
standard problem?
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(3,975 Views)
My guess is you missed some math library DLLs,
usually they are in \windows\system directory, are
there any implicit math library used by the
Virtual Fortran?
--Rongfu
In article <7reiut$om2$1@nnrp1.deja.com>,
> above error occurs.
on a
> standard problem?
(3,975 Views)
