Formula node- using C
Hi there,
I need to create a vector and for that I am using the formula node. I am doing that in C ( in which I really am a beginner) whereas in MATLAB the program some time runs some time it does not.
Attached is the program,  the error list says:
 Error on line 3 is marked by a '#' character: "  int32  j; double# Rv[14]; Iv[14]; for "
Can anyone help?
thank you in advance
(3,270 Views)
Accepted by topic author helaka
You have 2 syntax errors on that line.  The proper term is not double but float64.  And separate the two arrays with a comma and not the end of statement semicolon.
Make it look like this and the broken run arrow goes away.
float64 Rv[14], Iv[14];
(3,262 Views)
Hi Raven Fan,
Thanks a lot. it really helps.
Sincerely ,
Helaka
(3,232 Views)
