Formula node_Integer Values
Hi everybody,
I want to make measurements in a frequency sweep range, so I take the range between 10^5 to 10^8 Hz. In this range I give 50 measuremnts to be done.
All ok so far but the values chosen in this range are not integer numbers. Is anybody knows what fromula should I give to have this 50 steps in frequency as integer values?
(3,395 Views)
Hi Maj,
you can convert your floats into integers very easily!
Two ways to create an integer array with your values are depicted in the attached vi (LV8.2).
(3,383 Views)
Or, you could just do this:
Message Edited by smercurio_fc on 06-08-2007 09:37 AM
(3,381 Views)
Thank you both for your quick replies,
Unfortunately I have Labview 7 , so I can not open the VI's but I will try to build it as configured.
Thanks again!
(3,370 Views)
