Formula Waveform VI
I am trying to use the formula waveform VI to generate this equation " y(t) = 7exp(-10t)sin(20*pi*t ) + 2;
I put the parameters as follow:
frequency = 10
amplitude = 7
formula = exp(-10*t)*sin(w*t) +2
The formula waveform VI  did not work correctly because of the formula;
However, the book I read puts the formula as " formula = exp(-10*t)*a*sin(w*t) +2" and it worked perfectly.
Can someone tell me why I have to put "a" in the formula above. because the only difference is the "a" in the formula expression.
Thank you.
(3,301 Views)
If the only problem it's the "a" you can simply eliminate this,  putting this value equal to "one".
Or do you want other thing?
Software developer
www.mcm-electronics.com
PORTUGAL
(3,281 Views)
Hi okogidi,
when you look inside 'formula waveform' you will find 'f' and 'a' defined as parameter names for frequency and amplitude!
So when you wire those parameters you have to use those names in the formula...
Edited: And 'w' is already defined as '2*pi(1)*f' 🙂
Message Edited by GerdW on 03-12-2007 12:19 PM
(3,279 Views)
