Formula Node Troubles
I'm a beginner with LabVIEW and I am working with the formula node.  My program is not running.  The error I am recieving is "array indexing expected".  What exactly does that mean?  All my input arrays are defined outside of the node.
Message 1 of 11
(5,550 Views)
Don't be shy.  Post your code so we can see what you are doing.  This is a place of learning.  🙂
Bill
CLD
(Mid-Level minion.)
Message 2 of 11
(5,544 Views)
I also can't seem to get array outputs and a place to wire my error output.
Message 3 of 11
(5,541 Views)
You need to index your arrays in the formulas.  Are you trying to get arrays going out?  Scalers and arrays do not mix inside of the formula node.  You could probably do all of that in actualy LabVIEW code instead of using the Formula Node.
Message 4 of 11
(5,532 Views)
Yeah, I'm trying to get arrays in my outputs.
Message 5 of 11
(5,527 Views)
Hi a1,
- the formula node doesn't handle arrays...
- it doesn't handle error clusters...
- the help for the node also doesn't mention a function "ones(x,y)"...
Message 6 of 11
(5,526 Views)
Well that's annoying.  I guess I'll just try doing it without the formula node.  Any ideas on how to make it any easier? Thanks.
Message 7 of 11
(5,520 Views)
Hi a1,
an idea would be to use MathScript instead - when your LabVIEW license permits...
Message 8 of 11
(5,517 Views)
Ok, how to I access Math Script?
Message 9 of 11
(5,512 Views)
Hi a1,
when you have it installed (and your license is valid) you will find it next to the formula node in the structures palette...
Message 10 of 11
(5,510 Views)
