Formula Node - Embedded If statements
Yeah I was thinking of using that particular VI and reading in the output to the formula node. I figure at least that way I can make sure the criteria is true or not. I plan on giving that a shot.
Can I read in Boolean values to a formula node?
Message 11 of 17
(1,719 Views)
I'm not sure, but worst case scenario you can "bool->0,1"
Message 12 of 17
(1,715 Views)
I don't understand what that means. Could you please expand?
Message 13 of 17
(1,708 Views)
It's on the boolean pallette.
Jim
LV 2020
Message 14 of 17
(1,704 Views)
So it looks like this coverts whatever boolean value is read in to an interger value, correct?
Sorry, I am not next to my computer with LV on it right now.
Message 15 of 17
(1,697 Views)
Yes, you get an I16 interger. FALSE->0, TRUE->1.
Message 16 of 17
(1,695 Views)
Well, I implemented the in range VI and the boolean to integer VI and my code worked! Now I am running my program over night to collect data and make sure it runs properly. I am developed a data collection and climate control program. It takes temperatures read from  thermocouples and stores those values and uses those values ot make a series of decisions. Hopefully, with the code I changed today I can be done with this project. THanks for all of the help!
Message 17 of 17
(1,662 Views)
