Formatting a timestamp into string with $ specifier
Formatting a timestamp into string with $ specifier does not work; the formatted string is empty and no error is reported:
19061iB67D59F74C86F953
I have forced the width to 10 to show that the format is at least partially scanned but when it is omitted the timestamp field is empty.
I couldn't find this problem reported/addressed so here it is (LabVIEW 8.6)
LabVIEW, C'est LabVIEW
Message 1 of 9
(4,988 Views)
Ohhhh... Snippets!!! Code Capture Tool is a must. Congrats!
19073iEAD4C0EB70CD4DA3
Message 2 of 9
(4,977 Views)
Maybe it means that time isn't money?
___________________
Try to take over the world!
Message 3 of 9
(4,971 Views)
Also, I forgot to say that I can confirm this in 2009.
And, you may wish to have a look at the about dialog of the CCT. 😉
___________________
Message 4 of 9
(4,965 Views)
I just ran into this issue with 2014.  Did we ever get a CAR for this?
Message 5 of 9
(4,677 Views)
Ok looking at the format string, the expected output of the code would be "FILE2014-09-19-SN42.txt"
Instead we get "FILE          -SN42.txt"
I did a quick search on CARs and found nothing specifically addressing this issue although some similar CARs were filed. I will raise this problem with our LabVIEW developers and see if we should file a CAR on it. However, I don't know how high of a priority a fix would be since there are easy workarounds for this.
Daniel C.
Message 6 of 9
(4,646 Views)
I have a work around for this if anyone needs it badly I can share.
I use it to make human readable timestamp for putting into a text file.
Might not be in the format you wish for but it will give something.
Message 7 of 9
(4,633 Views)
""there are easy workarounds for this."""  Ahh there you go.
Message 8 of 9
(4,632 Views)
Yes, the simple work around is to put the timestamp first in both the string and the inputs.  But this is a bug.  There is no doubt about that.  A high priority?  Probably not.  Something that should be looked for when doing a revamp of the Format String?  Yep.
Message 9 of 9
(4,613 Views)
