Formatting Array to String challenge
@altenbach wrote:
@raphschru wrote:
If using subVIs from vi.lib is allowed:
And if not (or even in general!), we would probably do this.
(Of course we must be assume that there is an even number of elements)
I like this variation of that:
Message 21 of 27
(925 Views)
Not the simplest, not the most efficient. Just having fun with recursive vi (LV2021)
Ben
Message 22 of 27
(863 Views)
Using search and replace twice
Message 23 of 27
(858 Views)
If you would like to go with "hardcore" way, then something like that:
ARRTOSTRING_API void arrayToFormattedString(TD1Hdl LVarr, LStrHandle LVstr)
	char num1[12];
	char num2[12];
	int size = (*LVarr)->dimSize;
	int* arr = (*LVarr)->elt;
	//in worst case we need 25 chars for each pair
    MgErr err = NumericArrayResize(uB, 1, (UHandle*)&(LVstr), (size/2)*25);
	if (err != noErr) return; // Not enough memory
    LStrLen(*LVstr) = (size / 2) * 25;
    char* ptr = (char*)LStrBuf(*LVstr);
	size_t saved_ptr = (size_t)ptr;
    for (int i = 0; i < size; i += 2) {
		if (i) { memcpy(ptr, ", ", 2); ptr += 2; } // Add separator between pairs
        itoa(arr[i], num1, 10);
        itoa(arr[i + 1], num2, 10);
        memcpy(ptr, num1, strlen(num1)); ptr += strlen(num1);
        memcpy(ptr++, "/", 1);
        memcpy(ptr, num2, strlen(num2)); ptr += strlen(num2);
    int count = (size_t)ptr - (size_t)saved_ptr;
    err = NumericArrayResize(uB, 1, (UHandle*)&(LVstr), count);
    LStrLen(*LVstr) = count;
The only advantage — this code is roughly 5x times faster than native LabVIEW code:
Result:
But it only makes sense if you have a real performance bottleneck here.
Message 24 of 27
(842 Views)
@paul_a_cardinale wrote:
@altenbach wrote:
@billko wrote:
I'd actually rather see how Rube-ish we can get it.  😉
challenge accepted....
Well, I suppose that's a nice try; but it doesn't hold a candle to some of the psychotic code that I've seen over the decades.
Well, the RG part is subtle and mostly in the crazy way to build the string inside the formatting via shift register. While it looks innocent, this has always been significantly slower that e.g. autoindexing followed by concatenating. I also have the nagging feeling that constantly swapping the formatting introduces a few more flaming hoops to the compiler optimization.
Message 25 of 27
(818 Views)
And if I will use SSE2 version of itoa and avoid memcopies with running pointer:
    ptr += i32toa_sse2(arr[0], ptr);
	*ptr++ = '/'; // First pair
    ptr += i32toa_sse2(arr[1], ptr);
    for (int i = 2; i < size; i += 2) {
        *ptr++ = ','; *ptr++ = ' '; // Add separator between pairs
        ptr += i32toa_sse2(arr[i], ptr);
        *ptr++ = '/';
		ptr += i32toa_sse2(arr[i + 1], ptr);
(I added strlen at the end of i32toa_sse2).
Then it will be over 20x times faster:
I'm not sure about the real purpose of this challenge - whether it's in favor code 'compactness' or performance. This is just a fun experiment.
Message 26 of 27
(802 Views)
Originally, I had a need for the code.  Although I could think of a variety of ways to do it, I wondered if someone could come up with a particularly nice* way of doing it.  In the interim, I have eliminated my need for the code (the formatting now happens before the data are bundled into an array).
* "nice" as in: looks good on the block diagram.
Message 27 of 27
(795 Views)
