Formating Output w/ Concatenated string
I have inherited some code at work which is functional, but rather cumbersome.
During a test operation, some 30  items are tested, with results stored in local variables.
When the testing is complete, a Vi captures all these variables and creates a concatenated string.
That string is sent to a .cvs file and processed in Excel, which is not the issue.
This is the issue.
If the product fails, a 'tag' is printed out ( literally a tag, a 2"x3" sticky backed label).
The current process is simply to take the concatenated string, send it to a comment field on the front panel, then do a print screen.
There are no headers, no indication of pass / fail per specific tests - simply a string containing values seperated by commas.
Of course I intend to restructure the process, but I have higher priorities over the next several months.
Can anyone suggest a 'down and dirty' method to a) attach headers to the data and b) affect the text based on pass/fail.
In other words - a string which now looks like this  "8.9.08,555,1.47,5.1"
Would now look like - "Date: 8.9.08, PN: 555, TOF: 1.47, Voltage: 5.1"
with the bold text indicating the part failed the Voltage test.
I could simply insert headers into the current concatenated string, but the screen is already JAMMED full of
items. I'm hoping there is another option.
Thank you for any suggestions
Alan
(2,580 Views)
Hi Alan,
      It's certainly possible to set a sub-string to bold type.  Attached is an example of how to set font-properties of a sub-string within a string.
Cheers!
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(2,568 Views)
