Format pad with 0s bug?
I'm trying to format a number to come out as xxx.xx.  For example, 5.32 would come out as 005.32.  I thought this was as simple as using the format specifier %03.2f in the format into string function, but this doesn't seem to work with LabVIEW 8.6.1.  I don't have older versions installed but I thought his used to do the trick.
Is this a bug, or am I just confused?
(3,000 Views)
Are you connecting like this?
anyway, its in version 8.6
Message Edited by Parny on 03-03-2009 06:20 PM
(2,993 Views)
Accepted by topic author mikema111
That won't work.  If he had 999.11 it would show up as 00999.11  Not what he wants.
Mike, try format specifier of %06.2f.  That is a precision of 2 and a minimum field width of 6 (2 for the decimal part, 1 for the decimal point, leaves 3 for the integer part of the number)
(2,983 Views)
