Format into string : Minimum decimal digits
Accepted by topic author i.ayestaran
There doesn't appear to be a format string that will accomplish what you want, but this should.
edit: the way it's written, Min Precision of 0 or less will give you this behavior... 123 --> 123. (decimal on the end). That can be fixed easily enough though, of course.
Redhawk
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 11 of 15
(1,697 Views)
Really nice piece of code, many thanks!
Message 12 of 15
(1,685 Views)
I would recommend to find a solution that does not depend on the localized decimal delimiter. (, or .)
Message 13 of 15
(1,670 Views)
Just add another control for the delimiter, maybe an enum with those two possible values and (.) as the default. Or some dynamic way of getting the currently used delimiter from the system. But yeah, currently it definitely won't work if (.) isn't the delimiter.
Redhawk
Message 14 of 15
(1,662 Views)
Try this. Should not depend on localized decimal delimiter.
(It could be made into a malleable VI so it accepts scalars and arrays with any number of dimensions. :))
Message 15 of 15
(1,655 Views)
