Format a disk/SD-Card with LabVIEW
I want to format a SD-Card with LabVIEW.
Is there an example how to do this?
I've tried it with "system exec.vi" but there occoured an error (Fehler 2 ist bei Befehl des VIs "Systembefehl ausführen" war "format f:" aufgetreten)
What is the solution?
(3,266 Views)
Does the command work if you run it from a standard command prompt?
(3,263 Views)
