Format Hex String
Hi
This is a really easy question but I want final string to have only the first two digits (cut off all the 0's). I cannot figure out what is the correct format string to use..
Message 1 of 15
(7,498 Views)
Use the String to Byte Array on the String -> Conversion pallete.
aputman
Message 2 of 15
(7,485 Views)
I do not understand, can you show me an example?
Message 3 of 15
(7,473 Views)
Accepted by topic author mnanda98
Actually, instead of trimming the string, right click the "zero" constant you're using to change format and choose "Representation --> U8" and that's probably the best way.
Basically, one letter is one byte, and the zero constant you have there is an I32, which is 4 bytes, generating the extra 6 zeroes.
Message 4 of 15
(7,466 Views)
That makes sense, but for another part of my code, I need to use string (just formatting a string, no conversions involved..)
Message 5 of 15
(7,458 Views)
Edit:  Added snippet.
aputman
Message 6 of 15
(7,449 Views)
Thanks, but what if I do not want the spaces between the final string..?
Message 7 of 15
(7,438 Views)
You could index thru the array using a FOR LOOP and concatenate all of the values together into one string using shift registers.  If you are unfamiliar with these terms, I would suggest going thru tutorial videos to learn the basics of Labview.
aputman
Message 8 of 15
(7,427 Views)
The default delimiter when working with Array to Spreadsheet String is Tab. You can't put an empty string, but you can replace all of the Tab values if you really want:
You marked Kyle's answer as the solution, but keep in mind that that will only work if you have a single string character.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 9 of 15
(7,421 Views)
Just to un-rube your code a lot James.
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Bernard Books
Message 10 of 15
(7,391 Views)
