Format Codes for the Time Format String
Hello guys...
I have 1 simple question.How to write a code in time format string.for example...%H%M%S for HH:MM:SS.So I want to add fractional seconds in this code...refer to the labview help,the code for fractional seconds is <%<digit>u>.But I'm little bit confuse just now.Should I put like this : %H%M%S%digitu. Or any other else?...thank u
(5,871 Views)
If you want 3 digits of fractional seconds, you would use 3u.
A format of
  • %H:%M:%S%3u would give you: 23:24:00.343 (for example)
  • %H:%M:%S%2u would give you  23:24:00.34 (for example).
Don't forget the ":" if you want them in the formatted string! All clear? 🙂
Message Edited by altenbach on 09-09-2007 11:29 PM
(5,869 Views)
Here's the full set:
Ton
My LabVIEW Ideas
(5,857 Views)
Hi altenbach...
Thank U very much....I am very grateful for your help.Now I using Scan From String to scan this time/date string and convert the string according to format string.Can it convert  into numeric data type?. I mean all parameter such as / and : in date/time value could display in numeric data type too...
(5,856 Views)
Just convert it to a date/time record and use "unbundle by name" to pick all the parts you want. 🙂
(You only need to show the outputs you need)
Message Edited by altenbach on 09-10-2007 12:01 AM
(5,848 Views)
