Force broken wires with intrinsic typecast (between incompatible pointers/references)
I like using free software libraries in C with the Call Library Function Node, I'm currently programming the LibXML2 interface.  With it, I have DLL pointers to docs, nodes, elements, etcetera, defined as Magic cookies to locations in the DLL memory space.
When I create strict typedefs for nodes and docs, LabView allows me to wire a doc magic cookie to a node magic cookie (or pointer, and visa-versa) and only indicates an intrinsic cast. Is there a way to define a reference or unsigned 32 typedef that yield a broken wire instead of allowing it with the red dot of intrinsic casting?
(1,275 Views)
If they are the same data type and just different type definitions, there's no way to 100% prevent type definitions from casting to each other.
You could instead create a LabVIEW class for each of the different types of pointer.  With classes, the internal data is protected and only members of a class can unbundle the integer pointer that you'd put inside of them.  You would even get the ability to define a custom wire type so you would have different wires going on your block diagrams instead of the same 1-width blue wire going everywhere.
You could even add some inheritance.  For instance, a document is also a top-level node, so if you have one inherit from the other you can have it so that any VI that accepts a Node pointer also accepts a Document pointer.
(1,237 Views)
Thanks, good answer.
It hurts my head to think of a document getting inheritance from the node object since, due to the hierarchical nature of XML, is upside down thinking.
In general, the document includes a top level node and DtD stuff, it's not a slam dunk inheritance, but I see your point.
(1,219 Views)
