For loop with i+2 increment (only use odd index numbers)
I would like to implement a for loop into my design where I only use odd numbers between 1-49. However, I am unable to do so as the index in for loop is set to only increment by one. Are there any smart solutions to this?
Thanks.
(7,570 Views)
Hi salasjad,
Well, is using simple math considered as "smart"?
What about a simple equation like "number := i*2+1" to calculate your odd numbers?
What about using a shift register initialized to 1 and getting incremented by 2 each iteration?
Based on this requirement ("using only odd numbers") you could even use a case structure inside the loop to only do some work when i is odd… 😄
(7,563 Views)
I would not call it a "smart solution", but... take the index, multiply by two and add one.
Paolo
(7,557 Views)
you could even think about using something like the "Ramp Pattern.vi" function to create an array of odd numbers outside the loop.
(7,515 Views)
There are plenty of ways, it's just math, right?
(7,489 Views)
