For loop, possible to increment counter/exit loop?
I would like to know if it is possible to exit a For loop. I know
I can use a while loop but it would be nice to be able to
increment the loop counter in a for loop. Is this possible?
Mike
(3,733 Views)
> Thanks,
> Mike
No sorry it is not possible.
If you need this kind of functionality you will have to use a while loop.
You can then setup all manner of conditions to exit the loop.
Be aware that the loop will always run at least ONCE.
A for loop will run X number of times. This is determined either
at compile time (if the count is hard coded) or at run time
(if you use auto-indexing, or the count is a variable).
Kevin Kent
(3,733 Views)
Also remember you can make while loops auto index. Right pop on the tunnel
and enable this and the loop will then act more like a for loop.
Jim
> > Thanks,
> > Mike
> Kevin Kent
(3,733 Views)
Jim,
OK, that clears it up. Coming from VB I'm still figuring out the
differences.
Mike
> Jim
> > > Thanks,
> > > Mike
op.
> > Kevin Kent
(3,731 Views)
