For loop iteration parallelism
Am I wrong to expect numeric to be 0 when autoindexing an empty array? turns out enabling iteration parallelism outputs a 1 instead.
(1,834 Views)
Hi Lucian,
this effect seems to be connected with your "last value" output tunnel.
Outputting a default array seems to work correctly… (tested with LV2021)
(1,815 Views)
yes, I would also expect that.
But personally I don't trust this. If it is possible that there is an empty array at a for loop with auto indexing, I always place the for loop it inside a case structure and wire the selector to the output of array size function, so I can exclude arrays with size 0 and set default values manually.
_________________________
using LV 2025 Q3
(1,810 Views)
Interesting, never noticed this as I always implement a array size-based case structure to execute the content without the for loop in the case of size = 1 for high optimization.
It looks like for loop with iteration parallelism always runs once when auto-iteration enabled.
Santhosh
Soliton Technologies
(1,804 Views)
It only happens with "Last Value" tunnels. Auto-indexing are empty as they should.
(1,788 Views)
From the LabVIEW Discord: Darren has filed this as Bug 3432120.
(1,751 Views)
"Lasts value" tunnels would confuse me in a parallel FOR loop, because execution order of iterations is random and there is no predictable "last" in a chronological sense. Of course it is probably defined as the output from iteration N, and maybe the authors made an OBOE. 😄
(1,723 Views)
