For loop don't updates
First I'm new at labview ,
I'm trying to read 8 checkboxs vals and for each checkbox I'm queuing a single val witch will be a test.
I have a problem with my for loop it simply won't update and staying at 0 val ( only one iteration )
vi is attached , can any one give me some help ?
Kobi Kalif
Software Engineer
(3,042 Views)
I cant look at the code right now, dont have LV currently, but it sounds like you're either not looping at all, or not doing what you should inside the loop (but outside).
Could you post a .jpg/png? (usually we ask for the vi's instad 😄 )
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,040 Views)
Accepted by topic author Kobi_K
From looking at your cases it seems that you'll only get into the main 'True' case when your iteration equals 1. So for all other iterations it will be stuck in the false case where nothing is processed.
I would recommend having a look at some of the student tutorials available here: http://www.ni.com/academic/students/learnlabview/execstructures.htm
Windows 7. LabVIEW 2011.
(3,038 Views)
Thank you both ! As I thought  it's a stupid mistake 🙂
Kobi Kalif
Software Engineer
(3,034 Views)
