For loop and updated variable
here is something that  I am trying to do...but no success.
data1=0;
For [ x = 0 , x < N , x++,
{Write-Read buffer equipment 1} ;
t = result_buffer ;
data1 = data1 + t ;
{Write-Read buffer equipment 1} is a sequence that Write-Read the buffer of the equipment 1 and return the value t;
the value of data1 is updated after each loop.
Thanks for your time.
JM
(3,133 Views)
your code:
data1=0;
t = result_buffer ;
data1 = data1 + t ;
What is "N"?
(3,129 Views)
Thanks for the reply.
N is an integer.
Let's say N=100.
(3,125 Views)
You need a for-loop with N wired a value, and a shift register to keep track of "data1".
I would suggest going through some of the tutorials and heading over to the NI Learning Center for more training resources.
Message Edited by smercurio_fc on 02-29-2008 11:54 AM
(3,104 Views)
Thank you so much.
(3,093 Views)
