For Loop
I have an 1D array and i want my VI to search for a value which is bigger than for example 2. When he got it, i want him to give me the position in this array...
I cannot be that difficult, but i´m not able to make it!!
Thanks, Thomas
(3,333 Views)
Have a look at this:
Ton
Message Edited by TonP on 12-03-2007 10:59 AM
My LabVIEW Ideas
(3,330 Views)
Hi Thomas,
if you insist on using a loop:
You only have to check for empty array...
Message Edited by GerdW on 12-03-2007 11:46 AM
(3,318 Views)
The two solutions above are both great and which one's better depends a bit on your data. For example if your arrays are huge, but the match occurs typically in the first few elements, GerdW's solutions is probably more efficient. Ton's solution is simpler and easier to read and sufficient for typical data sizes.
If you have LabVIEW 8.5, you can also enable the conditional terminal for the for loop, significantly simplifying the code. 🙂
Message Edited by altenbach on 12-03-2007 08:44 AM
(3,282 Views)
