For Loop Iteration Different Conditions
I have an For loop with 8 iterations inside an Event structure.
I want to execute some code when iteration <4 and other code in the other case.
Can you help me to do this ?
Thank in advice!
(4,228 Views)
Accepted by topic author Claudinho18
Put a case structure inside the For Loop.  Connect the iteration terminal to the case selector.
Use 0..3 for one case,  4...  Default, for the other.
(4,214 Views)
While correct.  That sounds like an absolutely awful way to begin to use events.
Can you share code where this solution is used?
"Should be" isn't "Is" -Jay
(4,175 Views)
The question was about For Loops and different cases based on iteration number.  The event structure part of the question is superfluous.
(4,169 Views)
I thought my question was fair Bill???? We OK?
(4,164 Views)
Sure.  We're okay.
(4,158 Views)
