Font size block diagram
Hello everybody,
In the LV environment, I changed the size of the "application font" from 15 to 20, because my project has now also been switched to FHD (1920x1080) in the development environment.
Thus, the existing fonts in the front panel are now all in the right dimension.
Unfortunately, all fonts in all block diagrams (and there have accumulated some in 10 years) are larger and everything has shifted and is difficult to see.
Is there any trick to keeping the fonts of the existing block diagrams on 15 as before, or do I need to manually tackle all the block diagrams?
greeting
Jan
(3,035 Views)
As per my knowledge there is no such option for environmental settings change which  in turn will change the existing code module.
May be others can have different idea for the same.
(3,017 Views)
Hi Jan,
we already discussed this in the German LabVIEW board - even before you asked here…
(Please mark crossposts here the same way as you should do in the LabVIEWForum!)
(3,010 Views)
