Fomula nodes using complex variables
My big equations are becoming very nested in Labview's math graphics.  I noticed that Fomula Nodes don't take complex variables.  Is there an easy work around for this type of situation?
Thank you,
John
(2,981 Views)
If you have newer version of LabVIEW, you can use a mathscript node. It supports complex numbers.
What kind of equations do you have? Many times the wire code can be dramatically simplified.
(2,978 Views)
I have Labview 8.5, so I'll give the mathscript a try.  My equations envolve RF matrix transformations...no repetitive section.
(2,974 Views)
