Flushing a serial port - How to do??
I open a COM port on a cFP, then run VISA Flush IO Buffer.
I would now have thought that the buffer is empty - that is that there are now no more bytes at port and a read operation will not read anything.
I have read here somewhere that both the VISA open event and the Flush would empty the buffer.
This is not the case - there are lots of bytes at the port after the flush event - can anyone tell me how this is done correctly?
Thx!
Message Edited by Rodnebb on 02-06-2008 06:43 PM
(3,330 Views)
Have you set a mask value for the VISA Flush I/O Buffer? Use a mask of 144 to flush both the Receive and Transmit buffers.
(3,287 Views)
but.. why flush the transmit buffer - I don't transmit anything to this device, I'm only listening. I've tried both receive buffer flush methods.
(3,279 Views)
Well, if you've used the flush buffer correctly and more bytes keep arriving, they must be being continuously transmitted.
(3,256 Views)
