Floatingpointnumber
Hi there!
How can I get a floatingpointnumber out of four bytevalues?
I am working with an thirdhand vi and the calculate an measurevalue which
you can get out of an array. This value exists out of four bytevalues like
IEEE
standard. But I must have a real floatingpointvalue. But how?????
Thanx for you Ideas
Oli
(2,886 Views)
Oli wrote:
> Hi there!
> IEEE
> Thanx for you Ideas
> Oli
Oli,
LabVIEW stores value in IEEE. But 4 bytes is a single precision float.
Just type cast your 4 bytes to SGL type. If it's not the value that you
expect, try to swap bytes and words to see if your value is big/little
endian bytes oprder. If not, send to me your bytes and number you want
to see. Rarely need to convert bytes to IEEE format programmatically,
but possible.
Sergey Krasnishov
________________________
____________
Automated Control Systems
National Instruments Alliance Member
Moscow, Russia
sergey_acs@levsha.ru
http://acs.levsha.ru
(2,886 Views)
