Flatten to XML bug with unit variables in classes
I just spent about 5 hours trying to figure out why some of my class data kept resetting itself to zero.  Turns out that the part that kept resetting was the part that had a unit variable in it, and that fails to load properly from the Unflatten From XML VI.  It works fine if it's just a cluster, it's being in a class that's the problem.
I've attached the zip file with the example VIs.
Could I ask that someone with LV 2014 try this to see if the bug exists there?
Right now we're running 2011, but we plan a companywide shift to 2015 as soon as it comes out (and therefore, 2011 drops from extended support).  I'd like to know if I can just wait for the upgrade and then it will work, or if I need to redo about ~15 variables in classes with units on them that I had been counting on loading and saving using the built-in XML functions.
(3,876 Views)
I ran your VI on LabVIEW2014SP1 and have to say that the bug is still there.
UliB
(3,811 Views)
Have you raised a support request with NI? Sounds CAR-worthy to me.
(blog)
(3,791 Views)
I was planning on trying for a CAR only after confirming the problem hadn't been quietly fixed in the last 3 years.  I couldn't find anything in the changelogs but sometimes you never know...
Now that UliB has confirmed it's still a problem I will likely do so.
(3,732 Views)
This is a known issue with the unit variable in Unflatten from XML, but I have added this forum post information to the exisiting CAR #291163.
(3,684 Views)
Accepted by topic author Kyle97330
For the benefit of any future people who have the same problem and find this post, NI contacted me and let me know that as a workaround if a numeric is placed in a cluster inside of the class private data control, it will flatten and unflatten successfully.  I confirmed this works by adding a 3rd member to my example.
(3,601 Views)
