Flat Sequences
How can I get all elements of flat sequences in a single waveform graph in labview. I have three flat sequences with each having a for loop inside it. If I connect the results for each flat sequence inside the for loop to a graph, i will get the result displayed in the waveform garph. But I want all results to be displayed in a single waveform graph and a DAQ Assistance that can output this signal to DAQ card and to the connector.
I tried to makes arrays but only shows the result for last flat sequence.
(3,138 Views)
You need to post your VI so we can see what you are describing.
Are you sure you need to use a flat sequence?
(3,136 Views)
Here is the image of the VI
(3,129 Views)
Hi Stame,
In your first and second loop enable indexing (Output connector of express VI for loop). build array don't concatenate array.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(3,110 Views)
