Flashing white line when displaying an image
Does anyone know why I get a horizontal white line flash when I display an image, say a colored circle on a black background. When I put it in a loop, the line seems to scroll vertically either up or down. Increasing the refresh rate of the monitor makes the line wider and scroll at a different rate.
Do you have any thoughts as to how I could nullify this effect or where it comes from?
I have attached an example vi.
(2,941 Views)
Right-click on the picture indicator. Under "Advanced..", make sure "smooth updates" is checked. That should cure it. good luck!
(2,941 Views)
Thank you for the advice. However, it seems I already had that option checked, and I get the same results when the option is deselected. Strange. Do you have any other thoughts?
(2,941 Views)
Hmmm, interesting. What version of LAbVIEW are you using?
If I open your VI in 7.1, the option "smooth updates" is deselected and if I select it, the flickering goes away.
The flickering also goes away if I deselect "erase first".
So, try the following:
"erase first": NOT checked.
"Smooth updates: Checked.
Also try to see if there is an updated driver for your video card.
(2,941 Views)
Aha! The 'erase first' thing fixed it. Thank you so much for the help.
(2,941 Views)
