Fixing Tab Container Dimensions
Is there an easy way to setor "fix" the height and width dimensions of a tab container -- not the tabs themselves -- so that they do not change automatically when a "too large" front panel control or indicator is placed on them?  I am using multiple graphs, pictures, text and other itemson tabs and they occasionally change the size of the tab container resulting in a lot of extra effort.
(4,498 Views)
Oops. wrong board.
Now Using LabVIEW 2019SP1 and TestStand 2019
(4,491 Views)
I think you are probably looking for the tab control pane dimension property node.  You can also set the Autogrow to false to ensure that when you add an object into the tab control, it does not automatically resize the pane.
23816iE895286DA322B40E
Hope this helps!
Tejinder Gill
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
(4,471 Views)
That was exactly what I needed.  I was familiar with the "Auto Grow" as an option on the block diagram, but did not realize it was available as a property for fron panel controls.  Many thanks.
(4,458 Views)
Or, right click tab control  >>  Advanced >>  Uncheck AutoGrow.
(4,454 Views)
